Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 435 |
On my last trip to the UK. I monitored the values closely. I did manage to get 750km between Regens but part way into the holiday, I went for a motorway drive to get some passive Regens. It lowered the soot gram enough so that the active regen happened as expected. It is the lower-speed journeys that increase the soot lots.
17th Apr 2024 6:55am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 260 |
I would assume that rpm makes the difference. When I got the warning light (not red) I drove just a few miles (5-10) on the motorway in 6th gear at around 70mph.
17th Apr 2024 7:20am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1256 |
I think the regen process likes to engage fully on light over run, so if your cruising at speed and lighten the throttle, it’s an opportunity to shove more fuel down the pipe to get a burn.
17th Apr 2024 8:22pm |
Malbro Member Since: 22 Mar 2023 Location: Cumbria Posts: 15 |
So I decided to get the engine oil analysed on my 2016 sdv8 4.4 mostly to check the dilution %.Here are the results
10th May 2024 12:23pm |
GM260 Member Since: 17 Apr 2021 Location: London Posts: 3 |
And now in addition to all the monitoring, JLR is being taken to court in the UK and not just Australia over this issue:
17th May 2024 10:57am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1104 |
Technically the DPF is not defective it works. So legally they need to be careful how they approach this.
17th May 2024 11:33am |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 63 |
I had the same problem with my 2015 TDV6 I've ended up using the Jaguar F Pace TDV6 profile. This gives me most but not all of the things that I need. |
17th May 2024 7:28pm |
