Home > In Car Electronics (L322) > 2006-2009 head unit upgrade
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
Has anyone found a good reliable upgrade for this type of unit that keeps all the functions that is not insanely expensive? What doesn't kill you is just bidding it's time.
Post #612737 15th Nov 2021 9:05pm
Weegie
I and a number of others use this https://www.navtool.com/land-rover-range-r...rplay.aspx
This thread has a lot of information https://www.fullfatrr.com/forum/topic53128.html
Mine in use page 10 of the above thread. John
GAP iiD BT
Post #612739 15th Nov 2021 9:28pm
nemmi69
The unit, when you go to the link, looks wrong. Does not have the surrounding buttons as in the chat. What doesn't kill you is just bidding it's time.
Post #612740 15th Nov 2021 9:34pm
Weegie
It retains the unit. It's what's on the screen that changes so you can toggle between the original and the new. It mirrors your phone. Check out the thread and the website.
Look at the installation video on the website https://www.navtool.com/land-rover-range-r...rplay.aspx John
GAP iiD BT
Post #612743 15th Nov 2021 9:48pm
Weegie
Ignore the picture and follow through till you get the installation video which will explain it. John
GAP iiD BT
Post #612744 15th Nov 2021 9:55pm
nemmi69
Not sure I see that it does all the exiting functions. Also, doe this require an Apple phone? What doesn't kill you is just bidding it's time.
Post #612745 15th Nov 2021 10:01pm
Weegie
Or Android John
GAP iiD BT
Post #612767 16th Nov 2021 8:18am
nemmi69
Got to say, I am considering this
https://www.navtool.com/land-rover-range-r...rface.aspx What doesn't kill you is just bidding it's time.
Post #612822 16th Nov 2021 6:38pm
Wanderer83
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Rimini Red
Did you go for this in the end? Does the mirroring function mean you can control the iPhone/android via the OEM touchscreen? Or else you need to be handling your phone when driving which is not allowed?
Post #619169 8th Jan 2022 8:53am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I had the Navtool on my 58 plate, works off the touchscreen for Apple car play and was a fantastic bit of kit and straightforward to install.
Wish they did one for the MY11
Post #619897 13th Jan 2022 10:02pm
RovingRanger
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Grateful to find this is 2024 as was hoping it would be possible! Thanks all
Post #688547 20th Mar 2024 10:34pm
ChrisandandieP
Australia 2009 Range Rover Vogue TDV8 Bonatti Grey
Audio
The unit looks good, but what bugs me a little is the audio side. Using the aux plug and no bluetooth connection. I’m not sure if the aux input is better or worse than Bluetooth. Any thoughts or advice?
Post #691136 23rd Apr 2024 10:07am
garyRR
Using AUX means it can be susceptible to interference or ground loop noises (if no sound is on, the stereo can pick up noise from grounds of other equipment e.g. humming, or a high pitched noise in line with the alternator).
Nothing to stop you connecting the 3.5mm to a mini Bluetooth adapter to get the audio this way instead however. This would only work on later cars with the dark grey infotainment system, as the light grey systems don't support Bluetooth audio streaming. 2015 Range Rover Autobiography 4.4 SDV8
Post #691186 24th Apr 2024 8:39am
ChrisandandieP
That’s what I do. I have an excellent adapter that connects immediately, looks ok, and sounds ok too, but I struggle with the idea of the aux connection being old fashioned and susceptible to interference. I am surprised that there isn’t a device that is a Bluetooth receiver and has terminals also, that can replace the CD changer and use the MOST connection for sound to the head unit. My CD doesn’t work and I want rid of it, but if is removed, I break the MOST link.
My apple car play that works 100%
Bluetooth usb thingy
Post #691188 24th Apr 2024 10:05am
madnessgonemad
Re: Audio
The aux connection will always be better than Bluetooth because it is a permanent wired connection. I think 3.5mm aux connections are underrated in terms of quality. I use this in my L322 out of preference from my CarPlay unit. No background hum.
Try it and see!
Post #691189 24th Apr 2024 10:28am
