Home > Technical (L322) > Range Rover goes into extended mode
Stev
Austria 2009 Range Rover HSE TDV8 Alaska White
Hello. Sorry in advance for my bad English.
Since replacing my right height sensor, the car goes into extended mode when it comes to terrain height or access height. I bought the GAAP TOOL and calibrated the heights (front 493mm, rear 483mm). Unfortunately the problem was not resolved. Does somebody has any idea ?
Post #690764 16th Apr 2024 7:48pm
height sensor fitted the wrong way? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #690767 16th Apr 2024 8:44pm
Wrexus
United States 2012 Range Rover Autobiography Supercharged Fuji White
Did you by chance disconnect any of the air lines when you did this change?
If you didn't, then you probably need to replace the height sensor because what causes the extended mode is if during the raising of the corner, the computer can't detect any height change, then it goes into extended mode because it thinks the car is hung up.
If you did disconnect any air line, then you likely swapped the left and right side so when it is raising one corner, it is actually raising the wrong corner and thus the extended mode.
Post #691455 28th Apr 2024 11:41am
