Home > Technical (L322) > L322 In Tank Fuel Pump or Sender Wiring Failure |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 46 |
Is it the pump or just a faulty gauge wiring?
2nd May 2024 4:53pm |
Fiorano575 Member Since: 28 Nov 2023 Location: High Wycombe Posts: 16 |
That's a great question and I'm not sure. I broke down several months ago and recovered the car to a RR specialist. Since then I have made sure my tank is always half full.
2nd May 2024 5:00pm |
I checked the search but couldn't find any info on this issue. |
2nd May 2024 5:07pm |
Try these links,
2nd May 2024 5:15pm |
Thanks a bunch for those links! |
2nd May 2024 5:27pm |
AlexLRV8 Member Since: 16 Sep 2021 Location: Devon Posts: 13 |
There is a service bulletin about this somewhere. I had the same problem. It's caused by a faulty connector in the tank. I pulled the main pump, jet pump and senders out of the tank and cut off 2 or 3 connectors and soldered the wires together. Less than an hour and effectively a free fix. |
6th May 2024 10:46pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
Service bulletin
7th May 2024 7:26am |
Thanks for that. I thought it was an issue with the in tank pump failing? Is this wiring issue the real cause of fuel starvation when there is a quarter tank or so of fuel? |
7th May 2024 5:15pm |
Yes.
8th May 2024 12:40am |
