Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Cheers buddy |
10th Jan 2024 9:06pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2323 |
The bolt is M6 x 12mm, the same as used to hold the nearby pipe brackets. |
8th Feb 2024 9:30pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 264 |
Thank you 👍 |
8th Feb 2024 11:04pm |
Mfcetin Member Since: 26 Jun 2023 Location: Nuremberg Posts: 50 |
I also have oil on the right side of the engine and burned oil smell.
5th May 2024 2:26pm |
I took out the plenum to have a look at the oil cooler and I dont see any leaks there and it looks like someone has been there before.
8th May 2024 1:41pm |
dublicate post deleted 2011 Vogue SE 4.4 TDV8 |
8th May 2024 1:42pm |
How much oil are you using? It’s not uncommon for v8 to leak around the cam covers. I have a v8 merc and they are notorious for it. I tied to fix mine and only one side worked. It hardly uses any oil so I live with it. The only annoying thing is the burning when oil falls on the exhaust manifold.
8th May 2024 2:38pm |
Hi Richie,
8th May 2024 8:14pm |
Yes, I’m not saying it is that leaking on yours but it is a common leak on v8’s and usually ends up burning on the manifolds.
8th May 2024 8:38pm |
I think mine is leaking on the RH side.
8th May 2024 8:59pm |
No problem. You may be correct, perhaps in the meantime get a quote.
8th May 2024 9:07pm |
Some research material for you!
8th May 2024 9:11pm |
Sorry that’s the 3.6.. 🙄 |
8th May 2024 9:13pm |
Yes, I saw that 3.6 video and got happy as he didn’t have to remove injectors.
8th May 2024 9:18pm |
