Home > Maintenance & Mods (L322) > Message...vehicle raising slowly |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 |
Hi all...
14th Aug 2011 3:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
i would investigate that same area and see if something has been knocked or broken..seems a coincidence .. |
14th Aug 2011 4:34pm |
The message means it is taking longer than expected to raise the car - this is usually after a few requests, so the reservoir is empty and the pump is hot.
14th Aug 2011 4:49pm |
Thanks for the info.....I did notice that when I jacked up the RR, I had to really extend it to get the wheel off of the ground....do you think that may have had something to do with it. I had the height in access mode, but I didn't think to open a door or disconnect the battery. The wheel did lower a few times while I was jacking it.
14th Aug 2011 5:09pm |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 |
I have had this message sometimes. But mines when I pull out of my drive in access mode and floor it straight away
14th Aug 2011 6:50pm |
