Home > Maintenance & Mods (L322) > EAS Fault diagnostic |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Right, my RAC turned up this morning and cleared my EAS in no time at all. The only fault in the EAS was "Too much energy for regulation needed: front axle". Does anyone have an idea what this could be or is it a random error that might never turn up again?
16th Aug 2011 1:02pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34923 |
cant help re the error rob, but the lighter steering intrigues me.. |
16th Aug 2011 1:39pm |
Honestly Stan it was like night an day. My wife had it on sat to take her Sis and other bridesmaids shopping an she came home complaining about swore arms she drove this morning an nearly ripped the wheel of turning a corner. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
16th Aug 2011 3:03pm |
you've probably reset the firmware to what it was supposed to be ... |
16th Aug 2011 3:15pm |
Firmware? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
16th Aug 2011 3:42pm |
sorry what i meant was reset the ecu's that control the steering bit, anyways whatever you did, it worked... |
16th Aug 2011 3:54pm |
To follow up on this i had the same EAS fault ping up. When i contacted Storey when i had it last time he said this fault was due to a leaking front strut. To test it i put it in off-road height before i went on holiday and expected to return to it slumped down on one side or both, but returned home to nothing! Still in full height!
20th Sep 2011 8:35pm |
good point. BUT how do i know which ones got a home if the wont give me a clue. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
20th Sep 2011 10:29pm |
I would be interested to know too.... |
20th Sep 2011 10:38pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
Three approaches; - Ignore it until it gets so bad it does actually go down whilst stood still and you can hear it hiss - try some GOTEC LDS as recommended by Landrover (based on a Google search). You might be able to apply some and then drive it, although not too sure on that as I've never tried it. - replace both struts. Struts should be replaced in pairs anyway as there is a damper as part of the strut (unless you only replace the airbag itself). Of course it might not be a leaky bag or valve or pipe. It might be something entirely different. |
20th Sep 2011 11:08pm |
might give it all a good soaking with soapy water and see if anything obvious turns up. Its an expensive trial and error without any real clue as to the problem. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
20th Sep 2011 11:49pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Good morning... From experience, if you put the car on full height then stand with your back to the front wing and lift the wheel arch (only a couple of inches) if the bag has a hole you will normally hear a hiss when you take the weight off the bag...
21st Sep 2011 7:57am |
Hi Craig,
21st Sep 2011 8:14am |
@craig, can you reply to steve via pm please.. ... - .- -.
21st Sep 2011 8:22am |
