Home > Maintenance & Mods (L322) > Touch-up kit? |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I bought this too for mine. Its suggested on a lot of the detailing sites thats its best to mix the paint and the laquer in a mix of about 4 parts to 1 this is better than applying paint first and laquer afterwards as it improves your chances of a better finish.Its the laquer that gives your paint the shiney finsh. I did this however and found the laquer in the kit became very gooey and started to dry quickly making it difficult and lumpy to apply. I Had some halfords laquer I mixed instead with the paint and allowed me more time to use and touch up. The brush that comes with it is useless you are better applying it with a fine art brush as this gives more control . The secret is to apply as little as possible and build up in layers . I normally mix paint on laquer on a piece of old cardboard and use this as a palette. For a sctrach its best to apply using a cocktail stick. Hope that helps. Present :2008 TDV8 HSE
31st Aug 2011 10:39pm |
AMV Member Since: 10 Mar 2011 Location: EU Posts: 152 |
Thanks for the input, googsy2 . It seems to me it's like an art and you must have some talent to succeed
31st Aug 2011 11:02pm |
Lets say its work in progress I only know this information as I made a total the first time
31st Aug 2011 11:24pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
If you need touch up paint these people produce 100ml cans to order for about £10. The paint comes with pre-mixed laquer if you don't order laquer separately, even supplied with a paintbrush. The paint is good quality and is far easier to apply than "touch-up kits". I've used a number of tins on previous cars with good results. Also supply aerosol cans if you want to colour code bits or repaint larger areas.
1st Sep 2011 8:56am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
+1 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/] 04, 4.4V8, Vogue Oslo Blue with LPG. "You can sleep in your car, BUT you can't race your house!!!!" If something can't be fixed with a hammer....... You have yourself an electrical fault! |
1st Sep 2011 12:26pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
On a detailing course, the bloke advised to go to Halfords and buy a couple of empty touch up bottles, (they should have them behind the counter) and put your touch up paint in there, they have a finer brush and also a small metal nib which is ideal for stone chips. The dealer ones, the brush is too big. 2006 Mercedes CLS
1st Sep 2011 3:03pm |
