Home > In Car Electronics (L322) > Sat nav, cd player, reverse cam, screen not working |
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 |
have sometimes the same problem: the whole system is stuck on the boot screen.
10th Sep 2011 5:17pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Also check the phone module, if that not connected it shuts down. |
10th Sep 2011 5:28pm |
rory_mcw Member Since: 08 Apr 2009 Location: Angus - Scotland Posts: 113 |
I have left it sitting last night, and disconnected the battery for an hour.
10th Sep 2011 6:28pm |
Oh I forgot to ask: does this always happen?
10th Sep 2011 7:00pm |
how do i check them? i might have to take my head unit out.......
10th Sep 2011 7:48pm |
well I would start with the connections which are easy to check. (in the boot)
10th Sep 2011 10:29pm |
checked connections,
11th Sep 2011 8:51am |
If the phone module is disconnected or :censored:ed then it gives the same symptoms.
11th Sep 2011 1:53pm |
The MOST fibre optics are connected in a loop. So if you disconnect any of the MOST connectors, the system stops. In my 2006 MY S/C the Bluetooth module was f ed so the previous owner/workshop took the MOST connector out and "looped" it.
12th Sep 2011 10:55am |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 |
its a feature not a bug as they say does it very occasionlly on mine did it this morning switched off engine came back 5 mins later and works again, i think its something to do with damp, always happens when it has been a bad night, low pressure and what not, i learn to live with it as i know it will come back
12th Sep 2011 5:26pm |
i have a red light going into my bluetooth module.......... but nothing coming out of it.................. how do i loop the circuit? thanks rory |
12th Sep 2011 7:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34962 |
you need M.O.S.T connectors...if you can find them rory, they seem to be pretty rare.. .. |
12th Sep 2011 7:31pm |
