Home > Maintenance & Mods (L322) > Front seat removal |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3647 |
Is it just the 4 bolts holding the slide rails down and a quick unplug of the electrics ? Geoff |
13th Sep 2011 10:50pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Might be best to disconnect battery also just in case you forget to plug in one of the looms for seat airbag and your left with a fault light on . Cant advise on removal but nosey to know wjy you are removing seats? Present :2008 TDV8 HSE
13th Sep 2011 10:59pm |
Problem with rear door speakers apparently the wires chaffe under the front seats Geoff |
13th Sep 2011 11:03pm |
Thanks guys keys out battery disconnected it is. I think thats what's called belt and braces Geoff |
13th Sep 2011 11:11pm |
You do have to leave the batt connected till you've undone the seat bolts as you have to drive the seat back and forth. Drive the seat back until you can undo the front bolts, undo, then drive the seat fwd again till you can get at the rears. Tilt the backrest fwd and you'll have a balanced package as small as it's going to get. Then undo the rears, disconnect the batt (Follow procedure! Wait for the nav to shut itself off!), disconnect the plugs under the seat and remove by lightly lifting the seat out the front door.
14th Sep 2011 2:29pm |
Thanks Steve,
14th Sep 2011 8:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
i've removed both front seats without dis-connecting the battery...made sure the car was in sleep mode and the key out of the ignition..no airbag warnings at all.. |
14th Sep 2011 9:06pm |
Geoff,
14th Sep 2011 9:55pm |
you are absolutely correct steve...battery dis-connection is the proper way to do it, i just found it quicker/easier to remove the seat without dis-connecting it..bad habits are hard to get rid of. |
14th Sep 2011 9:59pm |
Don't sweat this boys, I will disconnect the battery - Health and Safety - and take the seat right out as you suggest Steve.
14th Sep 2011 10:04pm |
geoff , dont forget to turn the steering wheel fully left ,then right after connecting the battery back up...... |
14th Sep 2011 10:17pm |
Sometime later .....Like I said disconnect the battery Present :2008 TDV8 HSE
14th Sep 2011 10:47pm |
Geoff |
14th Sep 2011 11:21pm |
