Home > In Car Electronics (L322) > No Entertainment System |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
might be a fuse?, or look in the rear nearside compartment and have a look out for a silver box with a blue and white white connectors in to it, the pins inside the connectors might be corroded i hope this is of any use. |
17th Sep 2011 5:23pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
thanks for reply. i locked car and went away for a brew. went back out unlocked car and hey presto it all fired back up into action. maybe needed a moment or two to sort itself out!!
17th Sep 2011 6:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
glad its all fine again stu, but keep an eye on the battery cos if its fairly old it might need replacing.. ... - .- -.
17th Sep 2011 8:58pm |
@ Scarey.. what makes you lean towards a battery issue... curious??
17th Sep 2011 9:16pm |
just a thought that a 'worn' battery might not have had the power to get every thing going when you re-connected it but after having it connected for a while it did.. ... - .- -.
17th Sep 2011 9:20pm |
ok, good point i suppose and taken on board thanks.. Current: TDV8 (3.6) RRS HSE
17th Sep 2011 9:26pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
I would imagine the ecu stayed asleep when you reconnected your battery... In locking your car and leaving for a couple of mins then opening and putting the ignition on, normal service was resumed!
17th Sep 2011 11:10pm |
thanks for that Craig..
18th Sep 2011 7:19am |
