Home > In Car Electronics (L322) > TV Upgrade
You don't get DAB radio through a DVB receiver, just digital radio, which isn't quite the same......... Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #87179 13th Oct 2011 10:59am
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
comports wrote:
I'll check that tonight to try to narrow the issue. Thx
Out of interest - do you get DAB radio channels through your also.?
hello comprts,
iv got the above freeview box too and yes you get Digital radio when you tune in the channels.
good luck with your installation. Range rover td6 54 reg touch screen
Post #87180 13th Oct 2011 11:15am
tanertimur
Reformed....
would you say its definantly worth buying the upgraded areial, have you noticed the difference with the standard one that comes with the freeview box you got and the one with the booster.
Where in South are you. I pick up signal in london but not all and on the move its quite bad with the normal areial that comes with it. thinking of buying the booster that you have. Range rover td6 54 reg touch screen
Post #87181 13th Oct 2011 11:22am
Reformed
I live on the outskirts of Portsmouth, and we dont go fully digital until March next year. When I first installed mine I could not pick up anything unless I was parked on the seafront at Southsea!
So I played around with a few booster aerials until I found one that works.
It still gets the occasional glitches (but then so did the analogue TV) but its much better and it works ok whilst moving. Reformed
Post #87189 13th Oct 2011 12:23pm
tanertimur
so just confirm you have gone for something like this one.
http://www.ebay.co.uk/itm/Car-Freeview-Dig...2a112e1663
which works for you?
I thought you had your connected up to the OEM car analogue areial? Range rover td6 54 reg touch screen
Post #87190 13th Oct 2011 12:28pm
Reformed
Yes, all I then did was tap of the power supply to the freeview box for the booster power supply. You can also get a splitter for it so you can run 2, one on either side, which I considerd but mine works well with just the one on the left side of the car.
I did connect to the standard areial when I was toying around but the picture was hit and miss. I have tinted rear windows so outside you cannot see the ariel. Reformed
Post #87191 13th Oct 2011 12:35pm
tanertimur
cheers mate for the advice
i also have tinted rear windows. i think ill go for the 2 aerials on both sides.
thanks again Range rover td6 54 reg touch screen
Post #87193 13th Oct 2011 12:46pm
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
it would be nice to get a step by step guide on this for everyone to do
part numbers pics etc Thumbs Up
Post #87244 13th Oct 2011 5:15pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Watching this thread closely as I plan to do the same over the next few weeks.
I think Danny is right, we need a proper write up with images so we can follow suit.
Post #87254 13th Oct 2011 6:21pm
Reformed
My install has now been tidyed up, so theres not to much I can take pictures off.
I might be doing another one later in another Range Rover, So I will take pictures as I go. I could do a write up how I did it but it may be easier with pictures?
My install has now been tidyed up, so theres not to much I can take pictures off. Reformed
Post #87259 13th Oct 2011 7:22pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Right - plugged in my portable DVD player and got a picture straight away. At least I know its the TV box and no that leads.
Thanks for the suggestion. I'll contact the ebay seller for a replacement..!!
Reformed - Where did you pick up your 12v supply. I was just testing and picked up form the other side (drivers rear where the fuses are) but it would due neater to do it all in the left.
Once I get the new box I'd be happy to write it up with Pics as it seems a great upgrade for around £90 Ash
2016 SDV8 AB
Post #87290 13th Oct 2011 9:33pm
Reformed
All my wiring is in the entertainment compartment. The previous owner has had a dvd system fitted with screens put in the rear headrest so I basically took the live from that (as I found it was only live with the ignition on), I used the main earth point in there as well for the earth. Reformed
Post #87319 14th Oct 2011 7:02am
tanertimur
Mine is the MOST touch screen system, so i had to buy a GVIF interface which allows me to connect upto 3x AV devices and a rear view camera input which comes on auto when reverse selected. i do have pictures if any one is intrested i can post. If your after the pre MOSt system then Reformed is your man. Range rover td6 54 reg touch screen
Post #87390 14th Oct 2011 5:38pm
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
darren ( reformed ) i am getting the digital tv box thingy soon but am going to get my windows tinted first Thumbs Up then we can take the photos as we go along for these chaps. ONE LIFE LIVE IT
Post #87467 14th Oct 2011 9:48pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I'm very interested Thumbs Up
Post #87481 14th Oct 2011 10:16pm
