Home > Maintenance & Mods (L322) > Water Shedder Fitment
mjdronfield
Hi all,
I've just spent half an hour or so trying to fit the water shedder around the nav kit in the boot.
I have the shedder from Land Rover, and have even had the fitting instructions from the Service Manager.
How does the piggin thing go on ?
The pictures in the instructions don't match the water shedder I've got. they must have updated it.
I've given up now. Bit sad seems I'd took the nav bracket off and was all set.
I just can't see how it goes, or where you stick the edge......
(Though I've a good idea where it ought to be stuck !!)
Does anyone have a picture of it in situ ?
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #94631 26th Nov 2011 6:59pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
I have got a picture somewhere, possibly at work.
However, it isn't that hard.
Somewhere near the bead of black sealant are two pre-punched holes.
These holes go over the two (screws/studs can't remember) at the top of the first bracket you need to remove.
Once you have those in place, the rest follows.
Seek out the two holes.
David
Post #94683 26th Nov 2011 11:37pm
mjdronfield
You wouldn't think it'd be that hard would you.
There are no holes, pre made, or even marks for.
I don't know which is the front...........I'm assuming the longer bit of plastic goes down the back.....
......that means the sticky black bead thing has nowhere to stick.
If it goes the other way round, it sticks to the carpet behind the units.
To quote my Dad "I can't believe this !!" LOL
This seems to be the newer "pre formed" water shedder like, as one member said "your Mother would put over the arm of a chair".
No idea...........
Lets hope I don't have a water leak !!
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #94709 27th Nov 2011 11:17am
A carefully places black bin bag works equally well and only costs a few pence Thumbs Up
Post #94780 27th Nov 2011 8:12pm
rads
Post a picture up, and what is your part number.
Can't understand why there are no holes.
I think there are "Water Shedders" inside the doors as well.
Just wondering if you have got the right thing.
David
Post #94839 28th Nov 2011 9:47am
mjdronfield
Hi mate,
It's definately the correct part. Though its been updated since the TSB was released.........
Not managed to work out how to post images on here, I press the "Img" button and it puts some text in - do you put the file path next ?
The part is shown on daveo's pictures here ;
http://www.fullfatrr.com/forum/topic4551.h...p;start=15
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #94844 28th Nov 2011 10:02am
rads
Found the picture.
You can just see the two punched holes near the line of black sealant, where the studs come through.
HTH
David
Post #94852 28th Nov 2011 10:48am
mjdronfield
Many thanks.
I have now successfully fitted the water shedder. Thank God I hear you cry !!
The bit I thought was the front, was actually the top - don't ask.
Probably why I couldn't understand any of it..........
The only thing now is, I have a sneaky suspicion it would be better behind the carpet, not infront, then you wouldn't see it.
Job for another decade me thinks !!
All the best
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #94940 28th Nov 2011 6:09pm
