Home > Maintenance & Mods (L322) > Heated wheel |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
something in this thread might help..
16th Nov 2011 11:33am |
npikey Member Since: 14 Nov 2011 Location: Lincolnshire Posts: 59 |
16th Nov 2011 12:12pm |
Right, ive had a look and if i have it hard on lock the heater works only when i start to straighten up does it turn off, so bad conection on the steering wheel, can i use wd40 or had i better get some electrical spray
16th Nov 2011 1:20pm |
electrical spray would be my preference.. ... - .- -.
16th Nov 2011 1:41pm |
Right, ive had the wheel off and the only fault i can find is with the assembly that allows you to turn the steering and keep electrical contact, Part no (xzr000020) iv priced one up and they are £205 + the dreaded, whats the thoughts on swopping the wires from the heated steering for the wires on the voice control thinggy as I never use the voice button ??? any input would be gratefully received,
1st Dec 2011 7:14pm |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 221 |
I would try and get the part replaced rather than use the wires from the Voice button. It may be a PITA, but just think of it as another one-off cost.
1st Dec 2011 9:24pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
The heated steering wheel takes alot more power than the "voice button" so the power rating for the wires are lower and you will probably burn out the steering wheel slip ring...
1st Dec 2011 11:28pm |
Thanks guys, all taken on board, think i'll wait a bit as ive just spent £1200 on having the rear bushes replaced, ( Oh got a pair of rear drive shafts with dammaged ends if any one needs some ) and £744 on 4 new tyres so the wife's not happy about spending any more at the mo, Christmas is coming and she's a spending like no tomorrow , I'll have another look at the slip ring when ive got a couple of hours to remove it and pull it apart, |
2nd Dec 2011 11:00am |
