Home > Technical (L322) > Are these issues to sort or just the way newer cars are? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
The only reason I have noticed these two issues is that its different to my TD6 Vogue.
22nd Dec 2009 10:02pm |
1/ I have the same problem with the heater i actually started thinking my Thermostat was goosed .....
22nd Dec 2009 10:26pm |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 |
My climate takes a minute or two to pump out hot air. Same with cold. Does it have enough gas? In older cars there use to be a piece of glass on top of the compressor where you could see if was running low. I am sure it's not like that anymore.
23rd Dec 2009 7:40am |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
For the HK system the best advice i give you is to use it with everything at 0
23rd Dec 2009 1:29pm |
Cheers chaps Discovery 4 HSE
23rd Dec 2009 2:07pm |
