Home > In Car Electronics (L322) > TV Tuner Confusion |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
That's the newer style digital tuner as fitted in a D4 but the green socket is not used on the D4 either so you will be fine - Just connect up the other coloured plugs correctly and you'll be sorted
23rd Feb 2012 12:41pm |
SupaCharged Member Since: 30 Dec 2011 Location: England, Herts Posts: 29 |
thanks Ajay, will install it tonight then , many thanks |
23rd Feb 2012 3:24pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 733 |
What is the extra socket for ? |
23rd Feb 2012 6:05pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Not sure.
23rd Feb 2012 8:01pm |
I took my old one out, and bolted the new one in.. If you're going to do it this way, you will need to drill two more holes for the bottom mountings. I also put some spacers (2 washers on each mounting point) to allow for better air flow, as well as drilling holes in the mount opposite the fan.
23rd Feb 2012 8:52pm |
I've fitted it tonight but can't get it to work,I can't select TV/DVD from the audio menu , press it and nothing happens, tried power cycling the whole car with a battery disconnect as well, still nothing ..... I'm thinking I might have a dud tuner.
23rd Feb 2012 10:38pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
What do you mean nothing happens? Does it display anything on the screen at all?
23rd Feb 2012 11:05pm |
Pressing tv/DVD It literally does nothing , it doesn't go to the tv/DVD screen so I can't select any options , using the 753 diag menu it says "comm error" or something similar...... Plug the old analogue in and it all works again , albeit analogue....
23rd Feb 2012 11:41pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
When i fitted mine i had a problem with the green and brown ariel plugs connecting with the new unit (no signal and then no comms)... Make sure you have good connections on all plugs before you take it all back out maybe wasting your time Craig |
24th Feb 2012 12:05am |
Have double checked and reseated all connections three times ...... Still no good |
24th Feb 2012 12:12am |
No worries, worth a mention...
24th Feb 2012 12:21am |
JustinP, you have a PM...... |
24th Feb 2012 8:38am |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
So I installed my digital tuner, I chose pal 1, when I select auto there are 4 channels loaded but it will only show one channel won't let me change the channels..any ideas? |
24th Feb 2012 3:42pm |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
Have you all who are having problems purchased the cheap ones from eBay ? |
25th Feb 2012 11:15am |
