![]() | Home > In Car Electronics (L322) > Another faulty reverse camera. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi,
Think the other two connectors are for the Vision assist pack .
every time I reverse, at least twice a day |
Use the wee reflection thing that is attached to your windscreen , i'm sure it is there for a reason |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35863 ![]() ![]() |
fifth option is to wait and let the camera dry out...should hopefully be ok... ... - .- -.
Is it worth removing it to dry it out and then reseal the case with silicon sealer? |
if you have the time justin, it will give you an idea of any water damage if any.... ... - .- -.
Might be worth a try , but i remember on my old SC the picture went black a few times then went Grainy then came back then after a while gave up the ghost and chucked it , quite common fault on the 06 Mdls …
Yes, I remember when your camera was playing up, and the thought of spending £500 for a pi55 poor camera is seriously depressing. Although, I'm happy to spend a bit if I can improve the picture so that it works in the dark.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
was that a new price or from a breaker??
happymadison1978 -did you buy the loom because the connector was different, or was your loom damaged? |
My rear view camera worked intermittently when I set off from home this morning, but had stopped again when I got to work, so I decided to take it off and have a look inside.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
Great news Justin.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
happymadison1978, did your 2010 camera have 4 pins or the 2, do you by any chance have the part number for the loom
