Home > Technical (L322) > Won't start, help.!!!
Page 2 of 3 <123>
Worth getting the alternator checked to avoid ruining another battery...
Post #153509 26th Nov 2012 9:15am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Got the bosch battery everything worked ok last night. Won't start again..! Iid says immobilizer- B1103 enable crank relay short to ground or relay open..
What does that mean..? I'm getting it towed to garage , waiting on breakdown service..
Post #153865 27th Nov 2012 4:37pm
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
hello i had the same problem, relay under the ignition key part bmw 61326901961
Post #153866 27th Nov 2012 4:44pm
Lolo
Expensive for part? Easy to change?
Thanks
Post #153869 27th Nov 2012 4:56pm
madcima
I've got the original, you never know which bmw over the years may have modified the original replacement ... cost 70 euro, but there is also competition (valeo) very simple work ....
Post #153872 27th Nov 2012 5:02pm
Lolo
The weird thing is the key turns fine steering wheel unlocks..I hear an electric clicking sound at the ignition..
Post #153873 27th Nov 2012 5:06pm
madcima
sometimes feels a beep and a zzzzzzz near the gear selector ....
Post #153874 27th Nov 2012 5:09pm
madcima
http://www.fullfatrr.com/forum/topic14442.html
Post #153875 27th Nov 2012 5:12pm
Lolo
This sounds spot on, I just got the car started before tow company came out.ok this may sound like a ridiculous question but can I just spray some contact cleaner into the ignition or will that f Question k something up ..just to try it .
Post #153883 27th Nov 2012 6:28pm
madcima
I tried, just that you can not do get the product into the ignition, the contacts are on the side, you have to remove the butt of the lock
Post #153886 27th Nov 2012 6:41pm
Lolo
From searching the forum I have nailed the intermittent starting problem down to 2 possibilities:-
1 ignition relay immobilser issue
2 starter solenoid
So when it won't start again ill try whacking the starter, that should give me my answer. Ill keep you posted Thumbs Up
Post #153967 27th Nov 2012 11:01pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Lolo
On 2006 TD6, there is no external relay between the immobilizer and the starter solenoid. The immobilizer directly controls the starter solenoid.
The most probable cause is either a defective starter solenoid, a bad connection at the solenoid or a defective immobilizer (internal relay). Keep in mind that a defective immobilizer is highly unlikely.
-Bad connection: Look for corrosion on wires at the starter solenoid. Remove clean and sand if necessary.
-Bad solenoid: Use the hammer trick to test the starter solenoid.
-Bad immobilizer: When the problem occurs, verify that you have 12 V going to the starter solenoid when the key is turned to the starting position. You can either measure this at the immobilizer itself or at the starter solenoid.
Cheers!
Post #155320 4th Dec 2012 5:09pm
Lolo
Hi Patrick,
Thank you for taking the time to reply.
I will pass that info onto the mechanic. I don't think he hasnt a clue but I do think he would rather be doing some nice easy oil changes etc on the other cars he has in his custody!
As far as I can recall when I cranked the car, there was no power to the starter. All connections seem good and also did but the starter to check.
My issue is the same as Johnte's on this post which also turned out to be the ignition:-
http://www.fullfatrr.com/forum/topic14442-30.html
Post #155333 4th Dec 2012 6:01pm
Johnte
Does sound like the same problem I had, not too bad a job to do Thumbs Up
Post #155353 4th Dec 2012 7:04pm
PatGAPInnov
Site Sponsor
Hi Lolo
My pleasure!
"I will pass that info onto the mechanic. I don't think he hasnt a clue but I do think he would rather be doing some nice easy oil changes etc on the other cars he has in his custody!" Plausible!
In your case it cannot be the ignition switch. A defective ignition will cause the same cranking problem than Johnte had but you won’t have this fault code: B1103 enable crank relay short to ground or relay open.
The immobilizer receives the cranking command correctly from the switch but the starter refuses to turn. The problem is between the immobilizer and the starting solenoid.
Cheers!
Post #155356 4th Dec 2012 7:21pm
Page 2 of 3 <123>
