![]() | Home > Technical (L322) > Inhibitor |
| Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143
Can someone please tell me what the Inhibitor switch does and where it is mounted? |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044
The job of the inhibitor switch (also known as the XYZ switch or gear position switch) is to inform the transmission ECU which position the driver has selected with the gear lever. It’s bolted to the RH side of the transmission casing from where the selector shaft protrudes but is hidden behind a protective tin cover.
Here’s what’s inside the switch, if it helps :
That's a brilliant reply Phil, very impressed. Am i right in thinking this error code won't be picked up with the Autologic Diagnostics, only the Landrover T4 one? |
I'd be surprised if Autologic couldn't detect the error. In my experience it's just the transfer box shift motor potentiometer issues that Autologic fails to recognise.
Cheers for your help Phil, hopefully I'll get to the bottom of this, I've certainly got a lot more information now. |
Good luck |
Phil
| rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283
Hy Paul,
Still haven't checked fault codes, but if I put the gear shift into Neutral before starting I do not get the trans Fail safe error. I can then move the shift into drive and no further problems until I put it into Park and then get the fault.
thats exactly the same symptoms I had,and thats what I did to drive around the problem for a few days but as soon as I put it in park the message would pop up on the dash |
| Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125
It would seem you have also pinpointed my problem. One thing that noone mentions is the selector lights on the dash don't show which gear you are in. But the ones next to the transmission shifter any gearbox range indicator do show the correct gear. Only when the box is NOT in fail safe mode All the lights function properly Eddie the eagle watch out 👀 |
| lyonsimo86 Member Since: 26 Apr 2016 Location: Hull Posts: 3
Hi, I too have this problem, albeit very intermittently. Does anyone know if the BMW part (part no. 24107512755) will fit as its half the price of the Land Rover part (UHB500020)?
| Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395
Stan uses the inhibitor switch to edit the FFRR posts
| All times are GMT |
