Home > Technical (L322) > Loss of Audio
v8ranger
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Santorini Black
Loss of Audio
I have just replaced my battery,on starting it up all ok,but i seem too have lost all audio equipment ie: no Radio,C.D .the Sat-Nav & Tv work but have no sound.Also my DSP option has disappered from the screen.
I have checked all connections to the radio,amp cd & all ok,all relevent fuses ok.
Any idea's what else i can check??
Post #14859 14th Mar 2010 10:50pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Typically they will return tomorrow when you go out for a drive. Hopefully!
Post #14862 15th Mar 2010 12:25am
inkiboo
Switzerland 2007 Range Rover Vogue SE TDV8 Java Black
Same happened to our MY2007; control unit in the boot had died.
Post #14934 16th Mar 2010 2:51pm
Stebo
2003 Range Rover Vogue 4.4 V8 Giverny Green
Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
I've just had the same problem! If anybody can help please let me know
Post #17751 3rd May 2010 12:56pm
v8ranger
Very Happy I have now sorted it,it turned out to be the radio unit,managed to get one from flee-bay for £25.Fitted it and has been working all ok for the past 3 weeks. Thumbs Up
Post #17753 3rd May 2010 2:20pm
Stebo
How did you figure out what it was. I've taken out the black dsp amplifier which looks a bit corroded so thought it might have been that, just about to buy another one but now you've put a bit of doubt in my mind that it might be the radio unit.
Post #17912 6th May 2010 9:35am
v8ranger
I had also suspected it was the DSP amp ,but i thought i would try the Radio unit first as this had corrosion on the contacts due to water ingress,so i tried a radio unit from a friends one & everthing came back up.I can only assume the other unit's get there power supply from the Radio unit. (The Radio unit could possible have a dry solder joint,as mine would come back to life intermittanly).Very Happy[size=18][/size]
Post #17917 6th May 2010 11:56am
wart
hi all.my 2000 has lost the sound on the sat nav and the radio isnt recogising the cd changer,ive checked all the wiring and it seems all ok,in the previous posts it mentions dsp amp? ive found the amp in the boot{i think}but now ive found some loose wires labeled up phone,is there any buttons i can press on the radio/sat nav to see what they are set to. ive held the radio button in and it comes up FLAT on the screen,any ideas would be grate.
Post #18023 9th May 2010 8:37pm
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
2008 TDV8 touch screen
head unit locked this weekend
non of the buttons worked and display said paused..
couldn't change from cd to radio..
disconnected battery for 5 minutes... reconnected battery... he bingo... fault now gone..
more luck than judgement me thinks ! Mr. Green
Post #18040 10th May 2010 10:15am
Had a gremlin the other night. Would pause for a long time before playing CD, sometimes the volume can't be adjusted by the steering wheel and the voice control button stops working. After a shut down its all fine again.
had similar issue on the TD6 and then they just stopped happening! Discovery 4 HSE
Post #18523 19th May 2010 10:45pm
My Dad's TD6 has just stopped working for Radio and CD.
So, looking at the above it could well be the radio unit. Which one of the boxes in the boot is it? Anyone got a pic to hand? Discovery 4 HSE
Post #18524 19th May 2010 10:46pm
Duke Thrust
Mine's just done this, am going to pull the fuse and see if a re-set helps.
If not, it looks from the above that a new radio unit might be in order Sad
Post #20633 20th Jun 2010 7:44am
Duke Thrust
Pulled the fuse, left it for a minute or two, popped it back and all is well again Very Happy
Post #20712 21st Jun 2010 8:24am
bogie
similar problem here with mine now, getting worse
at random the radio starts playing up...sound just cuts out, wait a few mins then switch on/off on the left button, comes back....for a few mins anyway
the power light stays on, just sound that dosent
then random reboots of the nav computer
Im guessing a dodgy amp, and maybe some corrosion/loose connection...a job for the weekend to take them all out I guess and check all connections
if anyone spots a L322 2004 amp for sale anywhere post up here please, as usual, none on ebay Sad cheers
bogie
Post #55334 18th Mar 2011 8:39am
SteveMFr
Site Sponsor
Assuming pre- touch screen satnav.
Bit hard to see in this pic. This RR has 3 infotainment modules (4 if you include the nav computer):
- DSP amp (black) to the left rear of the electronics compartment in the pic
- TV module (silver) to the right rear (blue and white plugs barely visible)
- BM53 radio module to the right front of the electronics compartment - but not visible in the pic. It's also silver and has a big, square, black plug and an antenna connector
Check the fuse first, tho - not an unheard of prob.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #55338 18th Mar 2011 8:55am
