Home > Maintenance & Mods (L322) > led upgrade |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Ok I solved my puddle light issue without resistors. If u want that white led look without errors get these http://bit.ly/xg5fjB |
13th Mar 2012 8:02pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4989 |
just received my leds - (hundred years later) will try to fit them by the weekend All my spelling errorz are belong to me!
14th Mar 2012 10:59am |
ok update - footwell, sidelights and interior roof light LEDs fit but don't work - the rest is OK All my spelling errorz are belong to me!
15th Mar 2012 1:44pm |
Try turning the ones that don't work 180deg in the holders.
15th Mar 2012 1:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
i found my map lights wouldnt accept leds , [turned 90 degrees as well]
15th Mar 2012 3:34pm |
Well if ur car is being picky bout LEDs, u can get xenon bulbs, make sure 5000-6000 whiteness at least. They look just as good.. |
15th Mar 2012 3:59pm |
me stupid !&/$"!&"$%/!)§( i will try again for the headlamps ones. right now-... OK THEY ARE POLARITY SENSITIVE ! Thanks for the tip !!! All my spelling errorz are belong to me! 2023 FFRR L460 2020 Range Rover Velar |
15th Mar 2012 4:50pm |
15th Mar 2012 6:45pm |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 |
*daveo there is alot of discussion on the correct type of bulb for the approach light/puddle light.
15th Mar 2012 9:29pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi ,ok these are the resisters http://www.ebay.co.uk/itm/Range-Aluminium-...1202wt_700
16th Mar 2012 6:36pm |
So your saying you need resistors for the puddle lamp led bulbs |
16th Mar 2012 8:01pm |
yes you need to put a load on the circuit as the led dont draw any load..if you dont want to put the resistors on then goe for lolo's option. V8 facelift Range Rover Autobiography 22" wheels.
16th Mar 2012 8:29pm |
simon, i have just noticed you have the later mirros, dont think that it makes much difference,can you not fit these ones, they are already loaded
16th Mar 2012 8:42pm |
I tried LEDs with built in resistors, they wouldnt work for me in the mirrors, altho everywhere else on the car they do.. |
16th Mar 2012 9:05pm |
