Home > In Car Electronics (L322) > Front Cigar Lighter |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
This is going to sound stupid but......was the ignition on? My front lighter socked is a switched live....
14th Apr 2014 1:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
+1 what he said.. ... - .- -.
14th Apr 2014 1:08pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Yes, the ignition was on, the centre socket is also only live when the ignition is switched on.
14th Apr 2014 1:27pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The cigar lighter sockets are also switched through relays in the rear fusebox cubby. Could be that the relay for the front cigar lighter socket has gone.
14th Apr 2014 7:37pm |
Thanks for the advice. There is only 1 relay in the rear cubby, which feeds both the front and centre sockets when the ignition is on. As this relay is identical to the rear screen heater relay next to it, I swapped them over, the rear screen heater still works, with the ignition 'on', the centre socket works but the front one still doesn't
16th Apr 2014 11:57am |
re your .bmp, try converting it to a jpeg file. ... - .- -.
16th Apr 2014 1:09pm |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 |
how did this end? -03V td6
9th Aug 2015 10:40am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'm not too sure what type of lighter socket is fitted to the ffrr, but, the ones that they fit in the Landcruiser have a fuseable link in the socket, as well as the fuse in the box. And nine times out of ten if you overloaded the socket the link would blow before the fuse I found that with a bit of careful rejigging you could rearrange the terminals and do away with the fuseable link in the socket. So it might be worth putting a multi meter or test lamp on the wires going in to the back of the socket, just to make sure, other wise you will be changing every fuse and relay in the car and it still wont work Yesterday I couldn't spell Engineer... Today I are one!
9th Aug 2015 1:20pm |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
How did the cigar lighter problem end , did you resolve it.
1st May 2017 6:07pm |
