Home > General > how a ffrr looks |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
looking for my 'dream machine' on the web i've noticed that some ffrr's look better than others..they seem to sit better on the road ...would this be down to the suspension setting and if so whats the best setting for normal day to day motoring... |
16th Jul 2010 12:41pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
There are no 'settings' to play with. All FFRRs ride at the same height. Visual comparison differences will be due to people putting the car into access height for photos and/or different alloy wheel sizes. Discovery 4 HSE
16th Jul 2010 12:48pm |
so from normal setting does the suspension sink a bit when left standing .... |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Not sure why it would. System should be air-tight.
16th Jul 2010 12:51pm |
many thanks again fox/rruk |
16th Jul 2010 12:52pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Think there is also the 'just below normal driving height' (no manual control) that the car adopts at higher speeds (i.e. when on motorways etc). So there are 5 height variations in total I believe. Steve
16th Jul 2010 4:48pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Any 1 know how you can set extended off road height?
16th Jul 2010 5:20pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 830 |
Don't know if you can do it on later ones, or possibly I dreamt it altogether, but press and hold the up switch?? |
16th Jul 2010 6:38pm |
The motorway setting (lowers over 62mph/100kph) was deleted from later models. Not sure when, but I think only pre facelift cars have it. 05 model or earlier. Later ones have a "High Speed" setting instead that lowers the car by 20mm... providing you are doing in excess of 100mph/160kph.
16th Jul 2010 6:50pm |
I don't think mine drops at speed. To be fair though, with the electronics on the later one, it doesn't need to!
16th Jul 2010 7:14pm |
Fox, was about to answer the same and was impressed with your knowledge. I thought only I was so nerdy to know all that stuff!
16th Jul 2010 11:52pm |
I had a weird fault last year and when I put it in off road it would go to extended hight ,
17th Jul 2010 9:11pm |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 |
When i fitted side tubes to mine Ken got my car into full height mode but articially letting the car think it was offroad using ramps etc and got the car very high so we could get access underneath.
18th Jul 2010 2:54pm |
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 |
There's a guy on ebay from Newcastle area that can change all your suspension setting. Not seen his work or anything but think it's more for lowering the car. |
19th Jul 2010 9:59am |
