Home > Maintenance & Mods (L322) > The love affair is starting to die.... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Oh well at least you got it sorted, don't know about L322 parts but Britparts have always been known as 5hitparts in other Land Rover circles, their own make parts are built to a very low price, hence a very low quality...
12th May 2014 9:49pm |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 |
Hey Dave,
13th May 2014 12:29am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
We had the whole manifold complete with pcv and oil separator off in one piece so we stuck the pipes on then and with three pairs of hands and a ramp, managed to feed the pipes back to the metal pipes.Who do we blame for this shambolic set up...Land Rover or BMW ? |
13th May 2014 7:39am |
BMW, never blame the car..... Its like blaming the wife for something it will always come back and bite you im the There is nothing that can't be fixed with a hammer😜😜
13th May 2014 7:51am |
To true !
13th May 2014 6:59pm |
Well after all of the above, still have a mis fire from cold start ! Cylinders 1,3 and 4 show up on the code reader, along with lambda sensor before cat one ( which is only 3 months old ). Left the battery off for half an hour this morning then did a 30 mile petrol run. Was Ok when I re started 3 hours later so let in switch to gas where it was also ok and did 25 miles on lpg.
14th May 2014 4:38pm |
Dd5884 Member Since: 14 Jan 2017 Location: Suffolk Posts: 7 |
Did you ever manage to replace the small pipe at the bottom of the oil separator. If you did, how ? It looks like a swine ! |
17th Jan 2017 6:20pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 468 |
I don't know if it's the correct way but when I did mine I attached the small pipe to the bottom of the separator, had the small jubilee clip over the metal pipe down below, fed the 4 inch pipe through the unseeable gap and over the metal pipe down below and slid the jubilee up onto the 4 inch pipe as I did so.
17th Jan 2017 7:24pm |
Thanks Chris
17th Jan 2017 7:48pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
When I did my oil separator I also attached the 4 inch pipe to the separator first then fed it down over the metal pipe. I found that putting a bit of silicon grease onto the metal pipe first aided installation greatly and to be honest forgot to put the jubilee clip onto the metal pipe first so had to take the small pipe off. Then after putting the small pipe back on realised that I had put the wrong size jubilee clip on, then after putting the small pipe back on realised I had put the jubilee clip the wrong way round (it has to be a certain way to allow access to the screw head with a small screwdriver), so off again. Long story short I was panicking about the short pipe before I started the job but after putting it on and taking it off about 4 times I finally realised it's not such a bad job as it got much easier the more I did it.
17th Jan 2017 8:25pm |
Job now completed. It was a bit of a swine to say the least !
19th Jan 2017 8:28pm |
