Home > Maintenance & Mods (L322) > Knocking. Front Drop Link Replace & Freeing Seized Nuts |
Propane blow torch won't produce enough heat to remove stubborn seized nuts or bolts, you need a Mapp Gas blow torch
25th Sep 2014 9:43am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
I'll take your word on that 47P2 but the nut certainly appeared easier to hacksaw after a few minutes of having my wee blow torch breathing fire on it!
25th Sep 2014 10:26am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
Well done and it was all worth it |
25th Sep 2014 9:27pm |
+1 for mapp gas, super hot! There is nothing that can't be fixed with a hammer๐๐
25th Sep 2014 9:29pm |
Congratulations sir |
25th Sep 2014 10:28pm |
Thanks
26th Sep 2014 5:01am |
Well done. I hate using heat on metal if it can be avoided since you don't know if the material was heat treated and by adding heat to it (and letting it cool quickly) it screws up the material properties (for example making it brittle, a common problem when you cool steel too quickly).
26th Sep 2014 5:50am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
i like those words eugene, ''destructive deconstruction ''
26th Sep 2014 7:05am |
Hi,
15th Oct 2014 1:52pm |
Puzzled me for years!!! |
15th Oct 2014 7:20pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Someone at Land Rover decided to have a laugh and get everyone wondering why..... Just to Craig off....
15th Oct 2014 7:52pm |
Well whether you're both being seious or flippant to my daft question
15th Oct 2014 9:49pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Just wanted to say that a set of impact sockets (6 slided) are a big help in situations like this, and while I realise that the horse has slung its hook, they might be a consideration before the next job. Also a drill can come in handy, you can drill some holes in the side of the nut, and bash the stuffing out of it with a cold chisel and a knock-o-meter. By drilling the holes before you bash, you remove a lot of the nut and it gives up a lot easier Yesterday I couldn't spell Engineer... Today I are one!
15th Oct 2014 11:11pm |
No, being totally serious, it has one, hardened steel washer behind the top fitting, on the "wrong" side, and nothing on the bottom.... but who knows why?? Pete
15th Oct 2014 11:54pm |
