Home > Technical (L322) > non starting primary4.5 bar fuel rail 80 bar ,cars for sale |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
on way to work this morning 03.30 hrs the decided to throw a wobbly fuel pump seems to of packed up the one in the tank aa agents turned up within ten mins!!!! with flat bed and recoverd me to just round corner from house couldent get wagon down our road for the cars parked (nob heads)
25th Nov 2014 1:25pm |
Did you fit a genuine LR pump or aftermarket pump? Have you changed the fuel filter? |
25th Nov 2014 2:24pm |
both after market ,prob I have at min is the aa agents couldent get down my street so left car round the corner the aa have agreed to come back and move it to out side my addresss later today between 1800 and2000 only needs moving about 150 yrd lol have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
25th Nov 2014 2:34pm |
car outside house , so will have to look at it later in week as no time for next couple of days . have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
25th Nov 2014 9:58pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Not good when this happens at silly o clock, hope you sort it.....match normally works If it dont work.......burn it!
25th Nov 2014 10:14pm |
any ideas as to where to be looking ????? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
26th Nov 2014 8:17pm |
found out what the dtc 1255 refers to its the sensor on top of the fuel filter.
26th Nov 2014 11:46pm |
bump have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
27th Nov 2014 8:24pm |
sounds like it is sucking air into the system, if this is the case you will have all sorts of problems. But should be fairly easy to fix. probably a bust pipe somewhere. get under the car and have a look.
27th Nov 2014 8:26pm |
thanks northern will look over weekend ,shifts this week don't help lol have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
27th Nov 2014 8:32pm |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 |
Trainman, who do you drive for...?
27th Nov 2014 8:51pm |
You've probably been past my house a few times then, always have ews and freight liner trains coming through as I live on the freight line just south of derby! There is nothing that can't be fixed with a hammer😜😜
27th Nov 2014 8:55pm |
I'm guessing you live between Stenson and Chellaston then?
27th Nov 2014 9:00pm |
slightly east of chellaston There is nothing that can't be fixed with a hammer😜😜
27th Nov 2014 9:15pm |
