Home > Maintenance & Mods (L322) > Won't start when hot...sometimes...!!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7911 |
Since I've had the car it's done this, starts great first time of the day but then after a trip, sometimes, it won't start at all... you turn the key and the ignition comes on, the steering lock unlocks, but it does nothing when you turn it to start, just as if you had taken the starter motor off.... At first it was very intermittent but lately it has started getting worse, you now have to leave it up to an hour before it will start... sometimes it goes days and will start fine every time, yesterday it did it twice, today it did it once, but was then fine later on... sometimes a few tries and it starts....
28th Nov 2014 7:51pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
This might be worth a try - I had this on my p38 and it turned out to be the cable from the battery to the starter had internal corrosion. Nip down to the local factors and buy another cable and put it on leave the others there and see what happens should cost about a tenner. I ended up doing battery to starter and alternator to stater
28th Nov 2014 9:09pm |
Thanks chaps, pretty sure it's not the starter, although I could be well wrong....
29th Nov 2014 6:27pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
I hate things like that.
29th Nov 2014 7:15pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1694 |
Eidt: Must read all posts |
29th Nov 2014 7:44pm |
Thanks chaps, yeah tried that loads... forgot to say in the first post....
29th Nov 2014 7:53pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
From your description I think it is unlikely but I would check the earths. John
29th Nov 2014 8:17pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Pete, buddy, have you tried a new starter relay? could be a simple £5 fix. Are but hang on a minute we're talkin' L/R here, it's probably a special shape relay made by Vestal Virgins on the ninth Sunday of the month and therefore costs 1.5 pounds of flesh! Yesterday I couldn't spell Engineer... Today I are one!
29th Nov 2014 8:40pm |
For Starter Relay, read Ignition Interlock Relay, they just give it a posh name and a big price tag...... Pete
29th Nov 2014 9:15pm |
OK 2.5 pounds of flesh Yesterday I couldn't spell Engineer... Today I are one!
30th Nov 2014 12:50am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
Is it definitely only when it's hot ?
30th Nov 2014 8:25am |
Have you checked the cable to the gearbox and the linkage ?? Maybe when it warms up the linkage/cable moves out of "park" just a little too much so it won't engage the inibitor switch. In the Wiki Stan put the gearbox linkage clean up and grease up method. MY 2010 5.0 SC Galway green and sand interior!!
30th Nov 2014 9:06am |
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 |
Just worth having the petrol/lpg switch over solonoid schecked. Maybe this is happening at exactly the temperature the ecu allows the engine to switch over. A long shot I know!!! |
30th Nov 2014 9:42am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
I was thinking about this last night and I guess you have tried switching off the LPG - long shot but thought I would mention it to rule it out.
30th Nov 2014 10:17am |
