Home > Technical (L322) > ENGINE STUTTER 2005 TD6 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
When did you last change the fuel filter? |
11th Dec 2014 11:18pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Agreed... Filter or pump? |
12th Dec 2014 12:47am |
If the rev are increasing but the car is slowing its not the engine is it ? I would lubricate you gear linkage first it could be simply slipping out of gear , very common for the linkage to get a but gummed up and stop it engaging cleanly and a simple job to do . 2008 MY Supercharged
12th Dec 2014 1:38am |
jinx1959 Member Since: 08 Aug 2014 Location: North Ayrshire Posts: 16 |
Hi guys the fuel filter was only changed 2000miles ago. |
12th Dec 2014 8:44am |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 |
Just had this on mine, it was the low pressure fuel pump, it has been replaced with a genuine LR one and all is well again 2005 Range Rover Vogue with Supercharged Accessories
12th Dec 2014 4:03pm |
Agree on the fuel pump too but also check turbo inter cooler hoses, as the extra boost from booting the throttle could force open a hole which is not open at lower boost levels, reducing performance significantly. There is nothing that can't be fixed with a hammer😜😜
12th Dec 2014 9:54pm |
Thanks to everyone for the advice. I changed the low pressure fuel pump and changed the fuel filter. Car is now running ok. |
6th Jan 2015 4:36pm |
