Home > Technical (L322) > 4.4L TDV8 ZF 8HP70 flush : special technique? |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
do non OEM filters have reputation or is it just cuz its OEM that we feel it must be used?
16th Jun 2015 1:44pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Non OEM are built to a price and "their" specification which could be anything!!! The filter paper could be toilet paper or cardboard and you won't know till it either doesn't work and you run the bearings, fails and blocks an oilway or any other type of failure occurs, or it just doesn't filter too well and you wear your engine out faster......
16th Jun 2015 6:11pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Exactly as Pate says above... Never worth the risk IMHO |
16th Jun 2015 6:19pm |
Holy thread resurrection batman!
21st Jan 2017 6:24pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
LR service schedule state replace oil and filter every 9years/144,000 miles Regards
21st Jan 2017 8:33pm |
Who on earth would leave that complicated bit f kit with the same lube for 144K. Madness. Takes no account of climate, drive style, towing, etc etc. It does not look a hard job to change the oil either. At the MD the cost of the oil is probably twice the labour! 405 AB exec seats Baltic and Cirrus
21st Jan 2017 9:04pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
A competent indie can do the job. Had mine done by an indie a couple of months back.
22nd Jan 2017 11:14am |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
Hi guys, have flushed with this:
22nd Jan 2017 1:08pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
just tripped over this thread while searching for gearbox stuff, I have just been quoted £854 for a double flush by a localish independent. That seems like a lot of money to me? Current: TDV8 (3.6) RRS HSE
31st May 2017 12:21pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
stu, I did my last winter (120 K km) in ZF workshop in Vienna and it was 615 euros. |
31st May 2017 4:47pm |
