Home > Maintenance & Mods (L322) > Do the wing mirror puddle lights need error free leds ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
7th Jan 2015 7:01pm |
Stan, how bright are they compared to OE pal? Seen a couple which were yes blue... But quite dull in comparison... |
8th Jan 2015 12:47am |
technically these 6000k bulbs have less light out put than the 43000k OE ones but because they are a whiter light in my eyes they equal or better the OE bulbs... ... - .- -.
8th Jan 2015 9:25am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
can you link me to the ones you used in the mirrors? How involved is it to get to/replace them? I thought i recalled you have to remove the whole mirror etc.? PS...if you want the whitest/brightest OEM look for LED's ALWAYS go with CREE. Those are the only ones I do nowadays for all my cars. You will be able to tell its CREE as the LED looks like it has a clear shell and then a green chip inside it. |
8th Jan 2015 5:13pm |
COB [chip on board] are brighter for 'blanket' light.. ... - .- -.
8th Jan 2015 5:20pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
to remove the bulb housing point the mirror glass toward the sky to allow access at the bottom. if you shine a torch in you should see the the clip for the bulb housing. i released it using a thin screw driver. can be tricky but once you have done it a few times its a doodle.
8th Jan 2015 5:30pm |
thanks buddy! are those LEDs in the mirrors bright crisp white or more blue? |
8th Jan 2015 5:41pm |
yeah nice white light.
8th Jan 2015 6:56pm |
Mark, there are LED blocks available with a fitting kit (for any bulb holder) on the bay of e! "been covered here several times!" that will give you much more light than a single replacement bulb
8th Jan 2015 7:22pm |
If you take the two hidden screws out then the front of the light comes off for fitting |
8th Jan 2015 7:24pm |
http://www.fullfatrr.com/gallery/albums/us...re~209.PNG
8th Jan 2015 7:44pm |
go on..... |
8th Jan 2015 8:14pm |
got my number plate lights through the post today. looks great and no errors but i have noticed that the side lights and number plate lights flicker on start up for around 5 seconds then fine. anyway i can sort this out ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
9th Jan 2015 1:32pm |
if you switch off cold and hot monitoring with the iidtool ,this should stop the flickering. ... - .- -.
9th Jan 2015 1:40pm |
