![]() | Home > Maintenance & Mods (L322) > Do the wing mirror puddle lights need error free leds ? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6824 ![]() ![]() ![]() |
I had the same problem. Gave up in the end and put the originals back in.
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Both mine went, no error. Put in LEDs and it's fine. No resistance error as far as I know. You remind me of a young me, not much younger mind, perhaps even a little older! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
They don't work with LED's pal |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
Hmm strange. Iv got error free bulbs coming tomorrow for the side lights. Il give them a try in the mirrors first. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
Mine must be can bus error free then, that's not what it says on the tin. They do work tho.
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
So, in the same vein - would I be able to put LED's in the rear number plate lights (I think they look much better)??
No, that worked ok for me. It was just the wing mirror lights for some reason |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
CEEGEE, the number plate lamps will have to be error free, but they are as cheap as chips, I got 5 for £2.50 from ping pong via fleabay |
Yep, had a look last night - looks as though I can get UK supplied for about a fiver |
Error free bulbs came today for the side lights. Quickly tested them in the mirrors and they work fine. So I will be ordering a few more and think I will get the number plate ones as well.... addicted |
also can anyone help me on how to remove the covers from the main front and rear interior lights
NO DONT prise them off Mark... Open the glasses holder in the front and you will see 2 8mm headed bolts up inside, remove them and then the whole console will pull down from the roof... The front & rear lights are held in place with two crosshead screws from the rear |
Ahh. Thanks Craig. I knew there had to be something holding it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
i've just put 6000k xenon bulbs in mine, much better.. |
