Home > Maintenance & Mods (L322) > Upper tailgate wiring loom |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Just unplug everything, feed the wires out and then refit the new one... Feed your existing loom back through and re-plug it all back in
5th Mar 2015 10:01pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Thanks Craig
5th Mar 2015 10:14pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
I had mine changed and painted by a Bodyshop.
5th Mar 2015 10:35pm |
5th Mar 2015 10:45pm |
when you pull the loom out is it possible to pull a cord through attached to the old loom to make pulling the new one back through easier? There is nothing that can't be fixed with a hammer😜😜
5th Mar 2015 10:57pm |
Two more tips WD... Before refitting, fill it with wax oil Secondly, when you remove the strip above the numberplate (as your wanting to spray and reuse yours) be careful as there is a manufacturing dimple in the centre so they tend to SNAP in the middle whilst removing them sir |
6th Mar 2015 12:11am |
Stainless steel welding wire is always good |
6th Mar 2015 12:12am |
Thank you sirs, will let you know how I get on If it dont work.......burn it!
6th Mar 2015 10:27am |
