Home > In Car Electronics (L322) > Car Parking Sensor Issue |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 340 |
Sounds like a duff sensor or damage wiring. If you have a fault reader it may tell you which one is duff. If not put sensors on and listen to each sensor. As you get close to with your ear you should hear it click quietly. If they click the sensor is fine. This should help narrow down the problem. If more than one is duff maybe wiring loom. I had a problem with the rear loom on an 06.
19th Apr 2015 5:58pm |
jumbaleo Member Since: 19 Oct 2014 Location: Portsmouth Posts: 41 |
Thanks for the information. i went around all of the sensors and none of them are clicking.
20th Apr 2015 5:47pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
Or you sit in the car with the sensors activated, then get someone to put their hand in front of each sensor in turn. Being activated should make the constant beep become the usual beep beep until you reach the duff one(s) Discovery 4 HSE
20th Apr 2015 6:12pm |
Edited due to below:
20th Apr 2015 6:19pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Front loom cannot just replace as its part of the main harness... |
20th Apr 2015 8:52pm |
Okay, thanks everyone diagnosed as a single front sensor. All to be sorted in a couple of days. |
22nd Apr 2015 9:30pm |
