Home > Technical (L322) > Really weird one!! |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
Hi chaps!
3rd Jun 2015 3:54pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Could be similar to this Paul...
3rd Jun 2015 4:04pm |
Could be damp related as we've got a big crack in the windscreen at the bottom and we are getting water drips behind the brake pedal and dampness on the drivers side A pillar.
3rd Jun 2015 4:16pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2543 |
Paul, I had a similar issue a month or so ago. Hazards and brake lights came on randomly, it had been parked facing downhill during a rainy period. Returned it to its normal uphill parking and no issues since despite the rain. Something to do with dampness in the BCM? |
3rd Jun 2015 4:31pm |
Could well be that as its only been doing it since we've had the water ingress.
3rd Jun 2015 4:36pm |
If it is water on the BECM then you really need to get it out and clean it properly, the salts and impurities in "normal" water are what causes damage, if they are left to dry on their own they will sit and rot the board over a period of time. Pete
3rd Jun 2015 4:42pm |
Thinking about it, the LCM is on the drivers side "A" pillar, at the bottom behind the bonnet pull panel, maybe worth stripping that all out and cleaning it up... Pete
3rd Jun 2015 4:44pm |
Thanks, I'll have a look at that, it would make more sense to be the LCM as that is where most of the damp is collecting. |
3rd Jun 2015 4:46pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
Good luck, as said above if you end up with a soggy ECU, grab a can of contact cleaner from CPC or similar for a couple of founds to ensure all the deposits etc are gone.
3rd Jun 2015 5:33pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
+1 for the LCM |
3rd Jun 2015 11:22pm |
