Home > Technical (L322) > Effect of altitude on coolant? |
The coolant system is a closed pressurised system with the pressure determined and controlled by the radiator cap.
20th Jul 2015 4:09pm |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
So the idiot mechanic who used the same cap is to blame? (assuming he even changed the tank) |
20th Jul 2015 5:07pm |
I can't really say that. It's not inconceivable, but unlikely, the cap has failed in the closed position thus allowing the system to over-pressurise or it could even be the wrong cap in terms of pressure rating.
20th Jul 2015 5:33pm |
Your expectations of Kenyan mechanics are slightly higher than mine, even though I used a ridiculously expensive German owned garage.
21st Jul 2015 8:12am |
Seems your garage provides a service fairly comparable with that provided by a good few Main Dealerships in the UK. |
21st Jul 2015 9:26am |
Having had plenty experience with West African Sub Saharan mechanics (Nigeria) I share your scepticism on the quality of your mechanic. Having said that, plenty of idiots in the Netherlands (my home country) as well tbh.
21st Jul 2015 1:00pm |
The coolant is just coolant. I think. (i haven't noticed any oil in it though I did get a lot of sediment out when I drained it. Old pipes coated with scale.
25th Jul 2015 3:22pm |
I assume the leak is in the expansion tank ?? If so they are easy to replace (well on a 2006 SC there are, I replaced it myself when that one started to leak). But if your mechanic hasn't even done that (standard Nigerian practice, that is why I used to supply the parts and let them show the parts coming of as well and I dispose of them myself) than he needs a big kick up the behind. A bit of shouting usually makes them do their work properly (for a while).
25th Jul 2015 3:57pm |
I've just started doing all the work myself. I know a few honest mechanics but I don't necessarily trust them with a modern Range Rover.
25th Jul 2015 4:48pm |
