Home > Maintenance & Mods (L322) > Diesel injector cleaner (again) |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
Ive used red ex in the past, I'm sure some people say that it can cause more problems as it shifts dirt around.
2nd Aug 2015 12:06pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Cheers Steve.
2nd Aug 2015 12:35pm |
BG244 seems to be recommended, I have used reddex in he past and it made no noticeable difference👍 There is nothing that can't be fixed with a hammer😜😜
2nd Aug 2015 12:49pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I recently run a can of diesel purge through the engine and am happy with the results. The engine was running fine before so I cant claim any miracle improvements however the tick over is quieter now and fuel economy has improved by a little. There are a few confusing videos on how to use it with various hoses but after asking advise I chose to fill a new fuel filter with the purge and fit that before going through the running procedure. The can fills the new fuel filter with a small amount left over which I just added to the fuel tank when finished. It makes the process easy.
3rd Aug 2015 4:29am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
I used BG44 on the SC and thought it probably did some good.
3rd Aug 2015 8:04am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
I found it to be a waste of money but then again I found the more expensive fuels a waste of money. However there are plenty on here who claim to have had different experiences. I found that neither additives or fuels made any difference, however the car definitely ran better after a good wash and wax. Geoff |
3rd Aug 2015 8:17am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
3rd Aug 2015 8:33am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Two-stroke oil. Bit of a debate, but I've found it beneficial.
3rd Aug 2015 1:44pm |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 340 |
I've just bought a tin of that BG stuff. Only had the car a few weeks but the previous owner chucked a can in every couple of months and always ran the car on the super diesel. So, I thought I'd carry on his good work and she runs brilliantly. (Oh my, why did I say that, what's going to happen now) |
3rd Aug 2015 4:42pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
used redex quite regularly since the new year - not particularly convinced it's worth it. Did put some in the wives 645 and she says it did make a difference. I did notice that on the BMW on tick over there was quite a lot of smoke coming from both exhausts. mentioned this to my indie. when I told him I used Redex his first question was 'you haven't put that in the RR have you?!!'.
3rd Aug 2015 6:01pm |
Hmmm cheers guys.
3rd Aug 2015 7:37pm |
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 52 |
I use Forte products in my opinion they are the best available 07 Vogue SE Java Black 3.6 TDV8
3rd Aug 2015 11:56pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
I have found this makes a difference on 4.4 TDV8 power plants
7th Aug 2015 9:45am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Comma diesel magic is quite good. The wynns "diesel cleanup" one that you put directly into the diesel filter is quite good too.
7th Aug 2015 5:26pm |
