Home > Maintenance & Mods (L322) > Brake line corrosion |
Not unless you drive through salt water regularly. |
8th Aug 2015 2:08pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 586 |
think mine have been on since day 1 55 plate |
8th Aug 2015 2:12pm |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 183 |
My last MOT (June 15) picked up some corrosion on my rear brake lines. At 4.5yrs old and only 35k road miles I was not impressed. Landrover were not really interested especially as I had not purchased it from a main agent despite it having full main dealer service history. I eventually managed to get a 25% contribution and a reduced labour rate. I think doing both sides takes around 6/8 hrs, the dealership had mine for 3 days to do that and the front brake hose recall.
8th Aug 2015 2:52pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Thanks chaps.
8th Aug 2015 3:24pm |
8th Aug 2015 4:19pm |
They said the same to me. I think the turning point in my case was when I drew a conclusion from that statement that all Landrover demonstrator vehicles could well have been used off road and so using their argument would be far more likely to corrode than non Landrover owned vehicles. Landrover do not mention this as the point of sale. On a car that was 89k, you don't expect to have to replace the brake lines before the disks/pads!! I think there may have been a problem with the MY2010.5 cars. Mine has never been used off road or been kept near the sea yet has corroded, searching of the net shows I'm not alone. Jack 2016MY TDV6 Autobiography 2011MY 5.0 Supercharged Autobiography Black - Gone 2005 TD6 Vogue - Gone |
8th Aug 2015 6:23pm |
They accepted my claim for a new tailgate, that was replaced a few weeks ago.
8th Aug 2015 6:32pm |
I'll have to check mine, whereabouts did your tailgate go? I replaced the tailgate straps which were looking non to clever but didn't notice anything else, but will need to have a better look.
8th Aug 2015 6:37pm |
woodchip Member Since: 19 Apr 2012 Location: cumbria Posts: 132 |
I had the rear brake pipes replaced on a 2010 FF when it was 2 1/2 yr old and my 3 1/2 yr old FF has the same thing needing doing and also i have a corrosion blister on the wheel arch and the rear window side trim has fallen off AND the door mirror has a hair line crack in it, happened all by its self. And a bloomin great stone chip in the windscreen again.
8th Aug 2015 8:37pm |
Jack
8th Aug 2015 9:23pm |
