Home > Technical (L322) > First Fault Warning (Transmission Fault / HDC Inactive) |
jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 124 |
Hi.
1st Nov 2015 8:38pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7934 |
Usually that is one of the signs of a failing battery, check you have 12.6 volts with the car switched off and 14.4 volts with engine on and charging.... Pete
1st Nov 2015 10:25pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Or alternator. Those symptoms are very similar to what happened to me when the alternator failed and began sucking the battery dry of voltage. Alternatively it could also be a dead battery as suggested by Pete. A dead battery is cheaper so check that first. ______________________________
9th Nov 2015 10:24am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7799 |
Alternator is a very common fault on 2007 TDV8's
9th Nov 2015 10:29am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
The Alternator on my S/C went last Tuesday and gave exactly the same symptoms.
9th Nov 2015 11:10am |
