Home > Technical (L322) > FBH Sort of |
Hi Ziggy, that would only work if the AC compressor is driven electrically and not mechanically of the engine or if the engine is running (i.e. remote starting). I'm not aware that the functionality is there anyway, pretty sure not but wouldn't it be great in warm places or on warm days to have a bit of cooling before you get in.
7th Oct 2015 6:46am |
The FBH does double as a ventilator though. I used to use the timed climate to bring on the fans 10 minutes before I left work. It just uses the heater fans to ventilate the car. Not perfect but much better than raging hot if it was sat in the sun. |
7th Oct 2015 8:28am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Yes, in the summer it operates as remote/timed ventilation. Just takes the edge off the temperature.
7th Oct 2015 2:50pm |
That's a double edged sword. My humble Skoda Superb has it and it does work well. But it also means a new blower motor every 2 years. |
7th Oct 2015 3:26pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
I think the cut off ambient temp is 15 degrees for heating. higher than that it will ventilate via the remote. 405 AB exec seats Baltic and Cirrus
7th Oct 2015 5:35pm |
I have used it a few times but frankly when the car has stood out in the sun at 43 degrees all day it makes sod all difference 2008 MY Supercharged
8th Oct 2015 3:10am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
You can walk up to the car and hold the unlock button... After 3 seconds or so it opens the windows and sunroof until you let go of the button sir...
8th Oct 2015 8:26am |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
Thanks Guys
8th Oct 2015 10:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
its called lazy lock/ unlock mr zigg.. ... - .- -.
9th Oct 2015 8:31am |
AAAH-AR Sir Stan I'v seen that............so what do you do with the gizmo when your in the lazy lock /unlock page
9th Oct 2015 8:42am |
do this,
9th Oct 2015 8:59am |
