Home > Technical (L322) > fault codes ? |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
You have a scanner?
9th Oct 2015 7:15am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
^----- +1 for what @RR_P38 said
9th Oct 2015 9:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
there's a link in the wiki to a fault code site, might help.. ... - .- -.
9th Oct 2015 9:27am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Are you getting any symptoms?
9th Oct 2015 9:49am |
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 |
hi thanks for the advice, yes the codes were reset and have come back. only getting black smoke when hard acceleration.
10th Oct 2015 8:48am |
These are the ones:
10th Oct 2015 11:29am |
10th Oct 2015 3:32pm |
took off the hoses to inspect but no splits on either, tightened up the jubilees and test drove but still smoking |
11th Oct 2015 2:35pm |
Did you pull back the webbing round the passenger side upper, it normally fails under the webbing. There is nothing that can't be fixed with a hammer😜😜
11th Oct 2015 3:02pm |
yes had a good look under the webbing couldn't see any splits, it only smokes from the drivers side exhaust ? |
11th Oct 2015 4:07pm |
