Home > Maintenance & Mods (L322) > has anyone rebuilt their compressor (06my) |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 912 |
Occasionally i get the"suspension fault normal height only" message up on the display. I cured a similar fault on my 04 car by replacing the compressor. I have seen compressor overhaul kits available for a fraction of the cost of a full unit on ebay but wondered if anyone had any experience of these kits
10th Oct 2015 1:51pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
theres a how to in the wiki that might help.. ... - .- -.
10th Oct 2015 1:54pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
BagpipeAndy is the original maker of the kits, he is a lovely bloke and will sort you out and answer any questions you have, all the others are selling his stuff or copied it....
10th Oct 2015 2:21pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2543 |
+ 1 for bagpipe andy, great youtube video showing you exactly what to do |
10th Oct 2015 5:04pm |
Had a look at his website but cannot find a listing for the later hitachi compressor only the wabco version?? Paul
11th Oct 2015 9:29am |
I thought he was doing both, maybe wrong.... send him a message, or just get a kit from that other place..
11th Oct 2015 11:08am |
Iirc no one has made one for the later unit as it uses a proper piston like one from an actual engine!
11th Oct 2015 12:56pm |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
I did the Wabco compressor on my D2. In my case the bore was also shot, but fortunately I had a second compressor with a burned out motor.
11th Oct 2015 5:25pm |
The link in my first post lists a kit for the later hitachi unit used in 06my onwards and d3/rrs. I have sent them an email to check the part numbers and will order one if they are correct. I have got several used compressors from d3/rrs so if they are the same i will have plenty of spares
12th Oct 2015 8:22am |
Just managed to get the first link to work, and it all looks to have the right bits from what i know from the one I've dis-assembled.
12th Oct 2015 9:35am |
wokkadriver Member Since: 10 Sep 2012 Location: Hampshire Posts: 31 |
I bought and fitted this kit from these same guys. Works fine, and their videos are very useful, in combination with the wiki help on here… Getting the ring off the piston was probably the biggest difficulty. That and the supplied nut and bolt to rebuild the filter matrix was too short.
12th Oct 2015 8:53pm |
They returned my email and confirmed the kit i was looking at will fit my compressor so i have ordered a kit. Will let you know if it works Paul
13th Oct 2015 1:02pm |
I found that you have to be sure to cut off all the old piston ring with a sharp knife. Only then do you get enough space to pry off the cap on the top without causing too much damage. It is soft metal, so will chip easily. I put a few nicks in mine learning this lesson, but the filed out easily enough and have no impact on the function of the piston with the new ring installed. |
14th Oct 2015 9:02pm |
