Home > Maintenance & Mods (L322) > ZF6 gear oil.
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
ZF6 gear oil.
Hi folks.
I'm going to carry out an oil and filter change on my gearbox in the next few weeks. My mate managed to buy 20 litres of oil for the 5 speed box but I've been told you can only buy it in 1 litre tubs for the 6 speed. I want if possible to get the 20L and just wanted to make sure it's not possible before I purchase the small ones. Any advice is appreciated in advance.
Gary
Post #356913 14th Nov 2015 6:00pm
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
If you want the genuine ZF oil for the 6 Gbox then ive never seen it in any larger sizes than the 1ltr, most on here will tell you that its the only oil you can use. Some of the power flush guys do use a different oil that is available in larger sizes .
1 ltrs only I'm afraid but at least its only once
Post #356933 14th Nov 2015 7:35pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
^+1, just did mine the other week, and could only get it in 1 L bottles Big Cry - it is different to the 5 speed fluid. Thumbs Up
PS take a good look at your new Pan before you start fitting it - I got a new pan from Dan @ Duckworths, but it turned out that although the box had the correct part number on it, the pan in there was for the newer 8 speed and it is subtly different - I only found out after I had removed my existing pan when the holes wouldn't line up Big Cry Big Cry
(different number of holes, on different centres, and one corner has a sharper angle than the 6 speed) Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #356964 14th Nov 2015 11:35pm
Lost for Words
Yep, 1l bottles only. Thumbs Up
Arrow http://www.advancedfactors.co.uk/tyk500050...-174-p.asp Wink Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #357040 15th Nov 2015 12:07pm
Garyfax
Thanks lost for words. That's a good price, I've been quoted double that. Is there such a thing as a cheap version as I want to put the best stuff in. Also any idea how much I need?
Post #357470 17th Nov 2015 8:58pm
Lost for Words
Not quite sure what you mean by this bit? The Meyle oil is the same as the genuine ZF Lifeguard 6 - is that what you mean't?
Steve @ AF sells 10 litres with the filter change kits. Wink
Make sure you follow the correct level checking procedures: http://www.disco3.co.uk/gallery/albums/use..._level.pdf Thumbs Up Visiting from DISCO3.CO.UK
Post #357541 18th Nov 2015 10:56am
Garyfax
Just to clarify I was just wondering (due to the cheaper price) if the meyle was a cheap version of the genuine stuff? I have today ordered the oil, filter etc to service my gearbox. I ordered from advance as you suggested.
Thanks again.
Gary
Post #357620 18th Nov 2015 8:22pm
Lost for Words
Post #357694 19th Nov 2015 10:37am
