Home > Technical (L322) > Sorry FBH again SOLVED |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 |
As above, 2007 TDV8 Vogue, searched until my eyes are bleeding but no conclusive answer, my build sheet says auxiliary Heater, Park Heating With Remote Control fitted (I have no remote) it has been enabled in two places in CCF menu with IID tool, menu is on screen and can be set with timer buttons, light comes on to confirm and stays on for two minutes when key is removed, when time arrives to start, light goes out and nothing happens, when turning on manually from touch screen light flashes on once or twice but nothing else happens, on odd occasions fans start running but go off after ten seconds ish, not too sure where i go from here but cold weather coming and would be nice to be getting into toasty warm car in mornings, anyone with any ideas of what to check next ? nothing forthcoming and then after lots of googling and reading ------- Found this on GAP site
27th Nov 2015 9:50pm |
Bump to top as may help someone else |
29th Nov 2015 9:47pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Well done and thanks for posting back result to help others Howard
30th Nov 2015 12:21am |
dvb247 Member Since: 22 Nov 2015 Location: Cheshire Posts: 93 |
Can someone do this for my car please, in the Cheshire area |
30th Nov 2015 10:35pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
I have the same year RR as you, I never got a heater remote with mine and was under the impression that it was only available on the later model.
30th Nov 2015 11:40pm |
Have a look here
1st Dec 2015 12:33am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Unnecessary quote removed
1st Dec 2015 3:00am |
read what you have said and \I found this ! do I just need to buy a remote now and get it paired up
1st Dec 2015 7:36pm |
My post above with link
1st Dec 2015 7:37pm |
1st Dec 2015 7:39pm |
thanks Rob , much appreciated. I bought this car with stuff missing like the venture cam, now the remote, wouldn't you think the previous owner would sort those out as its a great feature for the vehicle.
1st Dec 2015 7:48pm |
people keep things like remotes etc to sell on separately to make a few quid more.
1st Dec 2015 7:56pm |
This is where i got mine from
my timed climate works fine from the dash, just want to get it remotely working. thanks for all your effort guys |
1st Dec 2015 8:12pm |
