Home > Maintenance & Mods (L322) > How often does your compressors work? |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
Mine will run any time I add weight or remove it from the car (passengers or cargo in or out) but not all the time - sometimes it runs by itself for no reason that I can think of apart from maybe topping up? It does not run all the time though just now and again |
28th Nov 2015 1:38pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
It seems to depend on all sorts of things... like Brian says it comes on when you change load, it also does it more when on bad or uneven roads and also whenever it drops out of motorway mode...
28th Nov 2015 3:47pm |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 |
Thanks guys! Very helpful information Just got a bit suspicious since the car bin fault free for several months now hehe L322 Vogue 2003 |
28th Nov 2015 4:26pm |
Don't worry, it won't be long....... Pete
28th Nov 2015 5:33pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
I have anger issues with my pump. It's new, and everything works ok. However, if I leave the car in say off-road mode, I can guarantee it will mess about trying to stay high, and it will definitely kill the battery, so it's dead the next time I go to drive it. If it was just sitting on its belly, flat down, and the battery was full (charged) this would not bother me. The fact that the car fusses about when locked etc, annoys me. If I was super-technically minded, I would find a wire to put a switch into, to disable this 'sleep/wake and pump/sleep' battery killer. There must be hundreds of our cars, with a tiny leak, that end up with new batteries, only for the problem to repeat etc. |
28th Nov 2015 9:55pm |
Very easy to wire in the pump to only work with ignition on, it may still mess about and end up on the floor though...
28th Nov 2015 10:43pm |
