Home > Technical (L322) > CV Gaitor |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Yes there is a special clip which needs a special pair of pliers to attach it sir...
11th Dec 2015 10:38am |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 |
Thanks Craig,
11th Dec 2015 10:39am |
Look at both sides OS - NS and see if they are identical? And compare the replaced one to a rear one on your car sir |
11th Dec 2015 10:42am |
Who would have thought it was that obvious!! |
11th Dec 2015 10:43am |
Apparently it was a full kit from Land Rover. I must just be very very unlucky. |
11th Dec 2015 11:17am |
Better fitting the stretchy rubber CV boots, they are more plyable and last much longer |
11th Dec 2015 12:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7912 |
I don't wish to cast dispersions on your garage but are you sure they did the work the first time, a faulty arm sounds a bit weird, it's an arm with a bush in it and maybe a balljoint at the other end, depending on which one it is...
11th Dec 2015 2:52pm |
It seems odd. I have spoken to the garage and they say that the boot doesn't have a clip to attache to the shaft side. As I am typing this it sees to make sense as obviously the shaft needs to rotate in order to drive the wheel.
14th Dec 2015 2:44pm |
The shaft and the CV joint and the boot all rotate at the same time. I think you need to find another garage if they think it shouldn't have a clip |
14th Dec 2015 2:47pm |
Sounds about right!! Know any good LR garages near by anyone? |
14th Dec 2015 3:02pm |
There's a good non LR garage in Carluke that I would recommend
14th Dec 2015 5:30pm |
Excellent, will do!
14th Dec 2015 5:48pm |
