Home > Maintenance & Mods (L322) > Hit standing water fast & hard |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
plastic wheel arch liner rubbing on a tyre i expect.
12th Dec 2015 10:13pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
My money is on the wheel arch liner - possibly grill section at the front of it?
12th Dec 2015 10:14pm |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Its definitely metal on metal rattle and scrapping ? Does the wheel arch lining have any metal ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
12th Dec 2015 10:45pm |
All plastic i think. Could be a water shield on one of the brake discs.
12th Dec 2015 10:49pm |
Exhaust heat shield |
13th Dec 2015 12:17am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
None of the above ......
13th Dec 2015 12:24am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 442 |
Agree with dolphinboy. They crack around the bolt fixing points and break loose. I discarded mine on my Td6. Never noticed any difference and no problem on the MOT. That said they are there for a reason so best to repair if it turns out to be that. |
13th Dec 2015 12:39am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
+1
13th Dec 2015 12:41am |
id already suggested that. |
13th Dec 2015 1:04am |
I only read the plastic bit at the beginning of your post |
13th Dec 2015 10:33am |
Zircon, you are right but u called it a water shield.
13th Dec 2015 10:41am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
Yes to this, ours did the exact same thing recently, sounded awful when driving the car as well! Backing shield had rusted and the bolts had pulled through the plate. |
13th Dec 2015 10:47am |
Permission to laugh if it turns out to be something else ? |
13th Dec 2015 12:49pm |
They're often referred to as splash guards, grit guards, water shields, heat shields and more often than not, rattly bit of tin on the back of the brake disc. In different vehicle manufacturers parts catalogues, they're given all sorts of names. |
13th Dec 2015 2:21pm |
