Home > Technical (L322) > Towing electrics again |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
Exactly the same as mine. Only the rear park assist disabled. I decided to live with it. I figure that having the suspension raise and lower if I wish to be an advantage. I can use command shift if I require different gearing and I'm not too bothered about the rear fogs - in those conditions the more lights the better in my opinion. |
12th Feb 2016 11:46pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Having control over the height of the car can be an advantage, especially when towing a long caravan offroad... I have in the past sited my caravan in less than ideal sites, when working at events, and having control over the A frame and the rear heights has avoided a lot of damage to the tin tent.
13th Feb 2016 2:12pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 695 |
Fair comment on all points! But, I didn't request the tow electrics to work that way, its what it should do, that's all! Had I not gone down the Land Rover route on installation, then it wouldn't have bothered me! 2014 vogue se |
13th Feb 2016 4:11pm |
Point taken, you paid for it, not excuses Yesterday I couldn't spell Engineer... Today I are one!
13th Feb 2016 7:41pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 |
As usual you pay for the expertise and get problems and your expected to pay your way out of it, despicable Many thanks
13th Feb 2016 8:03pm |
I personally would have an issue that they fitted the tow pack, and obviously didn't test it at all, until you took it back screaming............ I would have thought that they would test the kit to make sure that it was doing everything it was supposed to........ Still what does some spotty little apprentice know, all they have to do is follow the pictures in the L/R workshop comic
14th Feb 2016 1:45am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2984 |
Just found your thread Chef!
26th Feb 2016 12:40am |
100 Mph
27th Feb 2016 8:33am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
you are kinda right and wrong Chef, the 2002-2005 years lower around 60-65mph and the newer FF's come down at 100mph.. ... - .- -.
27th Feb 2016 8:52am |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 |
Slight highjack but how do you get the sat nav direction on your dash? Mine is 2010 lcd model.
27th Feb 2016 9:36am |
I'm going to the dealer, Pentland, Perth on Monday, with the tintent on the back! Now I don't care about the " features" it is, what it is! But I have now spent in excess of £1000 with them, and no further forward except that they have said there is a pulse in the wiring which is corrupting the signal to the rear towing electrics!! And suspect that the blackvue cameras that I've had fitted could be the culprit!! They were installed by a reputable fitter and have two feeds taken from the fuse box!!
27th Feb 2016 9:55am |
