Home > Technical (L322) > L322 2006+ Air compressor overhaul |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
Similar to cheap Chinese winches... you could try heating it up as the alloy expands more than the steel... think I'm at about a 50/50 success rate... good luck Pete
25th Feb 2016 6:13pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
FORGET all overhaul kits and parts for this horrible Hitachi compressor, special the piston makes problems, buy a new one or an AMK, only the WABCO (2002 to 2005) is one time able to refurbish, also there you need at the second time a new cylinderhead.
25th Feb 2016 6:37pm |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 137 |
Pete, sorry the crank AND armature shaft which I need to separate are both steel so no differential expansion possible. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black RR 2007 3.6 TDV8 Zermatt silver RR 2000 P38 4.6 Met red Mercedes 300TE 4-Matic Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly The restoration of the last three will account for my time during retirement! Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
25th Feb 2016 9:57pm |
