Home > Maintenance & Mods (L322) > Alarm keeps going off - neighbours not happy |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
If its anything to do with the bonnet switch then just unplug it. I did with mine, it's not gone off mysteriously since. Discovery 4 HSE
29th Feb 2016 9:44pm |
Isn't the beep when something inside the car sets it off, and the horn when something outside sets it off?
29th Feb 2016 9:58pm |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
Had a new bonnet switch fitted to mine - quick job, no more problems 2005 L322 Vogue Gold gone
29th Feb 2016 10:00pm |
ruffy Member Since: 11 Jan 2016 Location: North Yorkshire Posts: 70 |
Thanks for the suggestions. Don't think it's the bonnet switch as it is disconnected. There is nothing moving inside the car either. A mystery! 1982 SIII 88” diesel
29th Feb 2016 10:11pm |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
had a spider in mine set it off 2007 tdv8 se ,stornaway grey |
29th Feb 2016 10:16pm |
The door latches contain the alarm microswitches, if they are getting wet? That might be your issue??? I would spray some WD40 in each and then open and close the doors a dozen or so times before finally slamming each door hard... Try that? And at least it it does not work! Your neighbour will not think your lazy!
29th Feb 2016 10:41pm |
Thanks Craig, I will give that a go in the morning. 1982 SIII 88” diesel
29th Feb 2016 10:52pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7755 |
Try locking it with a different key fob - we had a weird problem with ours where one fob would lock it OK, but the alarm would go off regularly - the other was fine - I since replaced the faulty fob & have had no issues since. |
29th Feb 2016 11:01pm |
Thanks, will try that too! Craig, which bit of the door latches specifically need spraying with WD40? 1982 SIII 88” diesel
29th Feb 2016 11:04pm |
Its not scientific Im afraid Ruffy i would spray in the latch plate striker hole liberally sir |
29th Feb 2016 11:16pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
If that doesn't sort it, there could be a broken wire(s) in the door loom, I'm not familiar with the door switch operation, as to whether they are switching to live or earth, if they switch to earth then a single wire could be causing the fault. Yesterday I couldn't spell Engineer... Today I are one!
29th Feb 2016 11:41pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
does anyone know where the chirper is, as I had a few nightime false alarms, and wondered if I could tape over it, so its not quite so noisy. (2002 petrol) |
29th Feb 2016 11:55pm |
RHS rear quarter from memory?????
1st Mar 2016 12:09am |
They are usually switched to earth Miggit, that way when the car goes to sleep it does not affect battery life sir |
1st Mar 2016 12:10am |
