Home > Maintenance & Mods (L322) > Towing Mirrors |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
I tow a boat that is 8.5 feet wide (102"), though clearly a different shape.
1st Mar 2016 12:47pm |
Milenco Aero 2. Work fine. I added a 3rd clamp to each one to help with stability. Stay away from the grand aeros as they're bigger than is practical. |
1st Mar 2016 1:21pm |
Probably where I went wrong - I had Grand Aeros
1st Mar 2016 3:10pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
i use the suck it and see type with a convex one on the near side. Never fallen off but have a little safety strap on anyway, advantage is they adjust with the mirrors
1st Mar 2016 3:59pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 354 |
I have the large milenco mirrors for towing my large caravan. I have tried the stick mirrors but they slipped and occasionally fell off.
1st Mar 2016 5:20pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I use a set of these, I wouldn't tow without them ....
1st Mar 2016 5:54pm |
Not true In the UK, the law is complex & vague - you need to have an adequate view behind you - which is generally interpreted as you need to be able to see 20m back & 4m either side - so it's all about the angles & length of the trailer. You don't explicitly need extended mirrors. It's probably quite complicated maths, but fairly straight forward to test. In Europe it may well be different. |
1st Mar 2016 5:57pm |
Probably illegal now It's an offence to have anything protruding more than 200mm from the vehicle or trailer - whichever is wider - so with a wide trailer you might be OK I would guess that you can't buy anything which would typically be more than 200mm wider than the car just to be on the safe side. 250mm for post 2007 cars |
1st Mar 2016 6:15pm |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 155 |
All Many Thanks
1st Mar 2016 6:51pm |
They are the best mirrors that I've used..... and they are adjustable in width, Alistair, And every thing that I tow is 8 foot wide, and 10 foot high
1st Mar 2016 6:59pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Not true!
1st Mar 2016 8:16pm |
It's never been the law - just an interpretation - probably true for 99% of cars with caravans given the dimensions ,but the law is just that you need adequate visibility.
1st Mar 2016 8:52pm |
This may assist.
1st Mar 2016 8:57pm |
Still not entirely accurate - it's the width of the mirror, not the rear of the car that matters, but close enough I suppose.
1st Mar 2016 8:59pm |
